Hi
Is there any reason why every time a file is opened in the software all levels of the linked dgnlib are marked as used?Despite compressing the file and removing all the unused levels, remaining them as linked but without elements, when we open the file again they are all in use again.
Lot's of thanks
Borja
Hi Borja,
In reference to your earlier post, are you facing this issue only in ABD CE U3?
Warm Regards,
Subhamoy Kundu
Hi Subhamoy Kundu
It also happened in Update 2. Suddenly all the levels are in used with 0 elements inside.
We noticed the same in U2. In a reference all levels showed as used. When we detached and reattached the same file, it was OK.
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
Lot's of thanks for the answers
We have this problem with U3. It happens in a random way. It happens mostly when you "play" with reference files and then all the levels in the active file are used.
In ABD, with thousands of levels, it is very annoying. Compress the file or deteach and reattach references (we will try it Stefan) are non productive workarounds.
Any option?
Lot's of thanks.
Any option to avoid this issue?
