I am running AECOsim Connect update 3 and trying to use the Steel X & K-Bracing tools
However, I cannot find the member 'Rotation' setting in the 'Placement' options.
The Rotation setting is there as part of the Horizontal & Vertical Bracing tool placement options....
Is it somewhere else or has been omitted in the Steel K-Bracing toolset ??
John
You can find the option for 'Rotation Angle' in the 'Modify Structural Attributes' dialogue box for the bracing elements after placing a K/X Bracing.
I appreciate that the Rotation can be applied after placement.
But not having 'Rotation' as part of the placement options for X & K Bracing is a detraction from the functionality provided in the V8i version for these tools.
Do I have to submit a change request to get this back or is it already being looked into?
Yes, please file a Service Request. A Defect #895930 has already been raised. I'll attach your request to the Defect.
I have raised SR #7000781152 for this
