Hi Chang,
This feature is available in DEM(for V8i) or in Design View(for CE). Can you please clarify if you are facing any issue while using this or willing to get the workflow?
Warm Regards,
Subhamoy Kundu
Hi Subhamoy Kundu,
This is the Crystal 3D pipeline label performance.Is it possible for Aecosim?
Many projects have this need.
Thank you for sharing.
If you want a label that looks similar to the image you've attached, you will have to create a new DataGroup Annotation Cell for that purpose.
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/30533/escalator-annotation-cell
This wiki, while not focused on creating a new annotation cell, includes more detail that may be helpful:
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/36767/change-the-character-limit-of-annotations
You can also use the delivered Help by searching for the topic "Manage DataGroup Annotation Cells".
Answer Verified By: Steve Cocchi
Hi Steve Cocchi,
Thanks .
You're welcome!
