when I attach raster files the are not visible in the raster manager. How can I make them visible in the raster manager??
Regards Marc
can you create some screen shots please we need to see what you see
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Hi Marc,
Thanks for your question.
Could you please share some raster file with us, so we can check at our end.
Regards,Aniruddh
Dear Brenden
attached a screen shot. Raster is attached, but not visible in the raster manager. When you need more screen shots, let me know.
Thanks before
Marc
Update from Bentley Communities Brenden Roche can you create some screen shots please we need to see what you see View online  You received this notification because you subscribed to the forum.  To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
You received this notification because you subscribed to the forum. Â To unsubscribe from only this thread, go here.
when having to do my engineering homework I had this issue as well, so I used function key to 'FILEDESIGN;BACKUP;COMPRESS' which seemed to cause the raster reference to just go away and changed it to 'BACKUP;COMPRESS;FILEDESIGN' and that fixed the issue
The solution found by Marc to this question is in this post.
