We have a project that was done in Bentley Architecture. The project is now on construction stages and there are some changes that needs to be done on the floor plan. We are now using the extracted 2D floor plans to do the changes. But we can not make any changes to the floor plan because of the message "Triforma has intentionally restricted changes to this element". Is there a way we can make the 2D plan editable? Thanks for any help.
jun
BA 08050407
We had a problem similar but what I was doing was exporting to dwg for our consultants.
The interesting part was that I was giving these guys dwgs exported from BA and they were using Microstation by itself. And they still had that dialog box "Triforma has locked this element for editing". That is really funny..
But seriously.. I noticed that when you go to export this to dwg and you go into the dwg save options there is an option to "Remove application data" once I did that then they could edit the files normally.
Not a soloution to the problem above by any means but this is good info along the same lines.
Damon Aspden. Warren And Mahoney Architects.
New Zealand
