Hi Guys,
Can somebody show me the step by step procedure how to use the unification.
I try to find tutorial in the learn server but it seems there is not specific topic on it.
I have tried also but I could not successfully get the proper result.
Thanks in advanced.
Are the elements using the same Family + Part or a common unifier, and are they only touching and not overlapping?
Unify - dynamic vs cached.dgn
Hi Peter,
I just checked your SR and it looks like Sanchayan was not able to reproduce those results in CONNECT or V8i. At least not when the two elements are touching vs. overlapping (which is not supported by Unification Glue).
Hi Steve,
so far only touching working on my it did do unified the two element but for overlapping is not working, anyway that what I need for now.
Thanks for responding.
You're welcome! Unification Glue does not support overlapping elements so that would explain the difference. However, in real-world terms overlapping 3D elements should not exist, so the lack of unification in some cases can be similar to clash detection in pointing out potential problem areas.
Answer Verified By: IronMaxSteel
