WE do many franchises and would like to be able to copy the latest out the door and have all files within update.
Maybe this is saving it as a project template but not sure.
But there are times when I want to copy - for example" 10 detail sheets and all the details to another job - I need a way to do this where they update to that project.
Also sometime I open a project and the file is not recognized to be with that job. I'd like to see a way to tell the project to update all files in that job's folder to the current job
If you are copying the files and moving them to a new location the file association will remain.
Eric Milberger said:Maybe this is saving it as a project template but not sure.
WorkSet templates were added specifically for the situation you describe:
https://communities.bentley.com/products/microstation/b/microstation_blog/posts/configuration-installation-options-and-microstation-connect-edition-update-4
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/36391/connect-edition---create-a-new-workset
