Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
Building
OpenBuildings | AECOsim | Speedikon
Cancel
OpenBuildings | AECOsim | Speedikon | Forum
COPY AECOSIM STEEL COLUMN ALONG A PATH
State
Suggested Answer
Replies
Answers
Subscribers
92 subscribers
Views
Users
0 members are here
Offline
Adlf
over 5 years ago
Hi.
I'm trying to copy an Aecosim column through a 3D path but I can not get it.
The column must always be vertical and repeated at a distance of 4 m.
What is the best way to do this?
Top Replies
Offline
Steve Cocchi
Thu, Jun 21 2018 4:36 PM
in reply to
Adlf
+1
suggested
Hi Adlf, You're welcome. The video is a bit small so hard to make out exactly what is happening. So... This test uses the same process but with the Rotate Items option enabled. Granted, the distance…
0
Offline
David Trejo-Rodriguez
Thu, Jun 21 2018 5:09 PM
Can you share the file you are working with for review?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
Reply
0
Offline
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
