Well, this old bug bear has come into play again. Does anyone have a good, current breakdown of the Chinese steel sections and their attributes they are willing to share. I have my old xml file from AECOsim, but want to make sure it's up to date.
Chinese.xml
This is the Chinese.xml file within the latest CONNECT Edition Datasets. You can import it to Excel using StructuralShapesTemplate.xls and check if the attributes are upto date. Also, if you find some upgrades missing it would be great if you point them out to us. We'll try to make the required changes in the upcoming versions.
I'll compare it to what I have, thanks.
One issue that still exists with the chinese.xml library is the information for MTO's. Any chance this could be added with the rise in use of chinese sections?
Can you please file a Service Request explaining your exact requirements, so that we can raise an Enhancement based on that?
I'd be happy to, but it appears my account no longer has that ability. I can't review any of my older support logs.
Ignore that, working now. SR7000792868 added.
