The question is in the title. I'm using AECOsim (SS4)
Can pull the reference file dialog down from top bar but cannot open as a separate box to move around the screen and position where I want.
All others still working as normal (level display, level manager, raster manager, point cloud dialog, etc.)
ONLY REFERENCE DIALOG CAN'T BE OPENED AS NORMAL.
Never seen this before.
FraserG,
You could try renaming your prefs folder and see if it brings your Reference Dialog back to normal.
Here's a link - https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/23227/regenerating-preference-files-to-help-resolve-random-odd-behavior
HTH,
Larry
Can you post a screenshot of what you are seeing?
You may have the dialog pinned preventing it from opening as a floating dialog:
https://communities.bentley.com/products/microstation/w/microstation__wiki/38318/how-to-save-screen-space-by-pinning-docked-dialogs
I would definitely suggest reviewing the above first. But FWIW, I still have Ss4 installed and the only way that the Reference dialog doesn't open as a separate window is if I use the drop-down arrow instead of clicking directly on the icon itself.
