Hi All,
We'r having trouble extracting 2D drawings from a 3D model using the drawing extraction manager on AECOsim V8i SS6.
A solid that was used in an intersection at an early stage keeps showing up in the drawings even though it no longer exists in the model. Can't delete it or turn off its level in the 2D drawing because it will delete the current solid resulting from the intersection. Both are Slab Forms.
Anyone had this issue before ? It's happening only with Slab Forms so far.
Thank you.
