Compound Cells in Bentley Building Mechanical
I'm using Bentley Building Mechanical XM and I'm curious if there is the ability to change the way cells that come from Bentley Building Mechanical look when extracted, similar to the way compound cells work in Triforma.
A couple examples of what I'm talking about are:
1) Manual balancing dampers look great in the model. They look realistic and that is great. Unfortunately, when we extact them, all that we see is the small arm sticking out of the duct. It is difficult to see at smaller scales and I'm concerned the contractor will miss them. I end up placing our standard 2D symbol (basically a big "L" that goes through the duct) over top of them so that they will show up. Can the manual dampers be given a 2D symbol to replace them when extracted?
2)Diffusers/Grilles also look great in the model. However, our architects would like a standard box the size of the outside of the grille with a slash (for return air) and an "x" (for supply air) to attach to their reflected ceiling plan. It does make it much clearer which are return and which are exhaust. Can the grilles be given a different symbol to represent them when extracted?
 Thanks for any help you can provide!
 Rob
Parents Reply Children
