I am experiencing difficulties with the Walls tasks in the drop-down task list in the Place Architectural Elements section of the ribbon.
I am finding that all of these, eg. Break Wall, Glue Wall etc. are just not activating when selected.
I am obviously missing something here.
Can anyone assist?
This seem to work properly at my end as can be seen in the video:
Can you elaborate a bit where you are facing the difficulty or briefly describe your workflow where you faced the issues?
Tathagata,
Thanks for your response and for taking a look at this.
I have appended a video showing the issue I'm experiencing.
Note that it is the tasks in the Walls drop-down that do not activate when selected, including the Place Wall task, which, strangely enough is recognized outside of the drop-down menu
Rodney, I've moved this thread to the English language forum.
I'm not sure if this will help, but... try renaming your local \prefs folder to allow AECOsim to generate a new set, then try again.
