Hi all,
Is there any way to import RFA files into Microstation?
I have found one command few weeks ago to do it, but I lost my work history due to reinstalling software.
Anybody can help?
Tom
Hi Brenden,
Thank you for your post.
This way to import RFA's looks stunning for me.
Unfortunately my Bentley package cannot recognize this command.
Please see my AECOsim version below:
Is any way to upgrade my version to make this command available?
Many thanks
Tomasz,
Mea Culpa, IN 866, one of the keyins is different please see below each image
TFPACELL Wizard
TFPACELL IMPORT
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Answer Verified By: Steve Cocchi
Thank you Brenden,
I have tried this option before.
Some of selected RFA files work fine, but still got few I can't import.
I
Could I send you small rfa file you could have look where the problem is?
Cheers
Ok so the nature of this thread has changed and you need you to understand why some cells are failing. Please file a service ticket so we can track the issue if necessary.
In the meantime please share the file here and also tell me are the failing rfas the same Revit generation version as the the ones that succeed.
Rgds
Brenden
This issue is being looked into via SR 7000799910.
Please let me know if you did not receive my email.
Thank-you,
Larry
