How can I create the 2d element array with variables?
Hello, I can create elements array with 3d elements and variables. This is correct. See image.
I can also create 2d elements with variables and constraints. Also this is correct.
Then, I need to create 2d elements array, but I can't place the variable in this 2d array. See image.
I need a parametric cell 3d and other 2d similar
How can I create the 2d element array with variable?
Thank you
Joaquín
AECOsim CE updt_3
Parents Reply Children
