I am a PDS user trying to extract equipment arrangement and cable tray layout drawings that reference an AECOsim structural file that includes foundations, columns, bracing, handrails, stairs, ladders, beams and more.
Running Vector Hidden Line fails with the AECOsim file included as a reference file. Equipment models and cable tray models using PDS software have no problems until the AECOsim file is attached.
I do not know anything about AECOsim or the best practices when working on a PDS project.
Hi Ann,
This is difficult to answer because PDS isn't a product we know or support. In general terms an AECOsim file's geometry should appear the same when viewed in plain MicroStation. However, is PDS still based on MicroStation V7? If so, have you converted the AECOsim file from V8 to V7 format?
