Has anyone had much luck with Model annotation? I won't turn on for placed members and only shows on a member if I have it set first, but won't turn off. Very annoying.
Hello,Can you please elaborate the issue with some screen shots? And can you please also mention the type of members you talking about?
Any member. Previously, when you applied Model Annotation it applied what you set to all members immediately. Now, if I add a Model Annotation for say Section names, it will only add section name for new members placed. If I delete the Model Annotation and hit Apply it does nothing. Previously it would turn off say Section Name to all members.
Playing around some more tonight, you have to click on Apply All. Is this WAD or a bug?
Hi Bear,
You are right. You have to click on Apply All. This is WAD.
Why has this changed? We've only ever had to use Apply in the past.
As you already know, "Apply all" would place the Model Annotation on all members existing whereas "Apply" would place the annotations on new members created. Now, this functionality doesn't look bad either as different user's follow different workflow.
