Is there something similar to Autocad's linetype generation that can help my linestyles looking right? The line style is interrupted at every vertex and when it is too curvy it appears jut as a straight line.
Thanks so much!
Hi Yuliya - What program are you using? I can direct your query to a more suitable community.Regards,
Duncan Brown
Hi
if you are using a DWG file with linestyles and DWG variable PLINEGEN=0 is set, than this is a normal DWG /autodesk behavior, for "cury" situations.
Frank
Hi Duncan, I am using Aecosim. Thanks
No its a dgn. I know plinegen=1 can fix it for new plines in Autocad. I want to same in Microstation / Aecosim. I need to fix existing lines in my dgn file. In autocad I would go PE -> ltypegen -> on.
Hi guys - I'm going to move this thread to the AECOsim forum. Hopefully someone can assist more there.
