I am not getting extended elements and smart solids (DGN file saved from 1-model) in 2D extraction.
Created forward and cut planes correctly but after calculating extraction file not showing any content. Anybody help me in this case.
Reddy
Reddy, have you set up your Group models under Participants?
Also, which version are you using?
Hi Bear,
yes created group model in paricipant, group model also showing emapty
Currently I am using Aecosim building designer SS5
DGN file is saved from i-model and elements are smart solids and extended element etc.
The Group model should show your references that you're trying to cut.
The Group model showing elements. But not extracting to 2D
