HI guys,
I want to create a datagroup schedule that filters out (or in) items with properties that partly contain (or do not contain) specific text or values.
For example, I have elements that have the following type IDs: IF01, IF02, IF03... I want the schedule to capture all elements that contain the '"IF" prefix.
I know there are the following operations are available:
in, not in, greater than, greater than or equal to, less than, less than or equal to, equal to, not equal to
The AECOsim help does not appear to elaborate on the exact behavour of each of these or whether wildcards can be used.
I had assumed the 'in' or "not in" operators would serve my purposes but these do not appear to have the desired effect. Can someone here help me out?
Thank you
Good question... I've never really worked with schedule filters before but I am seeing similar results. I'm not really sure why though, so we may need to discuss internally and will then reply back.
That was a defect ... in fixing that we added better wildcard support for Update 4.
Answer Verified By: JoeyJM
Thank you for the responses gentlemen! Good to hear Tom. Will check these out when U4 is released.
AECOsim SS6 + CONNECT U4, Windows 7 Pro, 64Bit, Intel Xeon E3-1275 v5 @ 3.6GHz, 32GB RAM, NVIDIA Quadro P1000
