posted this in Microstation by mistake
My model appears correctly in plan and elevations, but disappears after a few degrees of a 3D rotation.
As it disappears, the accudraw coordinates jump from normal numbers (<100') to numbers in the millions, (8 or 9 digits, positive or negative.)
The camera can be on or off, still happens.
Front and Back clipping planes are off. This behavior persists across two different workstations, and also occurs in a file referencing this model.
Any thoughts?
dmg
CE u3
Can you please share the model so that we can have a look?
As a short term solution, we've found that if you hit the "Fit Screen" button, it returns.
here is the model
https://www.dropbox.com/s/mzt4ew4nt2cvcb3/330%20MAIN.dgn?dl=0,
note that there are numerous references that I did not share...
Re Daniel's comment, Fit View button does not cause the view to return
Apologies...the link expired before I could download. Can you please reattach the link?
here you go....
www.dropbox.com/.../330 MAIN.dgn
