render mode shows compound walls only flat 2D and not 3D Wireframe mode shows the compound walls 3D. I am really getting frustrated of this program!!!!!!!!!!!!!!!
Can you share us some screen grabs relating to this issue so that it would help us understand the issue better.
Problem appears when I make a compound wall of one height, place it and after that modify the outer blade to another height. When I make the wall before with a different height of the outerblade this problem doesn't appear. Anyway I think one should be able to modify the different blades also afterwards
Thanks anyway Souvik.
Update from Bentley Communities Souvik Mullick Can you share us some screen grabs relating to this issue so that it would help us understand the issue better. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
Hi Souvik,
when I manipulate the walls they appear again. So I can handle with it, but it looks to not correct in the program
3D Walls don't appear in render mode. You only see a flat contour. For example in the top. But the element is there in wireframe mode How can I make production? This takes me hours and can cost me the project! Kind regards Marc Op 22/07/2018 om 06:42 schreef Souvik Mullick: Update from Bentley Communities Souvik Mullick Can you share us some screen grabs relating to this issue so that it would help us understand the issue better. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse. -- VMarchitectuur.nl 0031(0)654641052
Could you upload the file here? I have to make a test case on it.
