AECOsim crashes when a 2D model is being published as an i-model
Hi
I'm coming across a very weird issue with publishing i-models.
The file crashes when published to am i-model and give the error message as below. It exports all files to i.dgn and only the native/live file from which it is publishing from, crashes and says can’t create an i-model.
Found a workaround - if the file is replaced( with contents moved from the faulty file to new file) then it works fine. Publishes the i-model well BUT with the below issues.
Expected output when the i-model is opened in AECOsim: The area indicated below – ideally should have no background.
Current output of the i-model when opened in AECOsim: Has fill in the area where it should have no background.
I'm not sure what is prompting AECOsim to show the 'grouped hole area' to be filled in!
Please advise on how to fix this.
Parents Reply Children
