Aecosim CONNECT U3
We are experiencing a recurring issue with transparency threshold in DV forward views being ignored when the views are cached.
During the set up of the DV in the composite model, transparency threshold is checked 'off' in the forward view.
However, when the resulting DV is displayed in the drawing file with cached view set to manual or automatic the transparency setting is ignored and elements with a transparent material attribute are still 'transparent'
Any pointers as to what we may be missing?
(Had the same issue in SS6)
Hi Rodney,
Could you please share a screengrab of the Cached Visible Edges Settings ? Also I would like you to try turning on the Transparency Threshold, setting it to 100% and share the results.
Hi Ranit
Three screengrabs appended. One showing initial setup in the model and the other two showing the presentation and settings properties in the drawing file
Could you take a look at your "Cached Visible Edges Settings", if the Transparency Threshold is turned on or not. I would also like to know if the elements with transparent material are referenced or not.
The cached view settings have transparency threshold toggled "off". See appended screen grab.
The elements with transparent materials are part of compound cells in models that are then referenced into the overall compound model used for DV's.
Raising a Service Request would be a good idea for this one.
