For some reason I can't get my tool settings to display. The box is there but its empty for all commands. Any ideas people?
Hello Boffinette,
Thanks for your question.Can you confirm is it file specific issue or not?also it would be helpful to know the Graphic Card details.
Regards,Aniruddh
As this is an English language query, I am moving it to the English language forum.Regards,
Duncan Brown
Boffinette,
Does this happen if you don't select Open Multiple Application Windows in File - Settings - Preferences - Operation?
Larry
You can also try this Wiki to see if it helps: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/23227/regenerating-preference-files-to-help-resolve-random-odd-behavior
