Has anybody had any luck in generating a Pile Schedule that will populate the X,Y,Z Start Point and End Point so the piles can be located??
Hi Ian,
Please let us know if Extracting Structural Element Coordinates - Steel or Concrete Piles Example answers your question.
There is some additional commentary on the VBA used in this example in: Some Excel VBA Tips.
Marc
Using Connect Edition 10.03.00.40 - its not the same as shown in the link but it is a start
You can use the Reports Tool to extract these Information
HI
I'm trying to do the same but the buildingdatagroup don't show up as an Item type folder.
How do I get that to be avalibale?
Robert
sorry for the late reply (vacation). you should see any item that is actually placed in your design file or reference
