9 years after an old post i exhumed in the forum, i still can't figure how to print the filled spaces and the walls.
The Sheet is perfect on screen but there is no way to print it as i want.
Below, screenshots of 3 variations around the problem
1. non raster printing = no colors for spaces
2. raster printing = no walls (I cant understand why for this one)
3. with "Spaces filled" ticked in the Dynamic View architectural settings = walls, filled spaces BUT they overlap, so we can't distinguish adjacent spaces
I will really appreciate help on this.
regards,
Xtov
Hi Christophe,
Which version of AECOsim are you using?
Marc
Hi Thomas,
sorry i forgot to mention it:
Aecosim 10.8.0.41 - US and French Datasets
I have created a sample test file in my end and the result i got is as expected. Please go through the below image and let me know if that helps you.
Warm Regards,
Subhamoy Kundu
thanks for the feedback,
I suppose you ticked "spaces filled" in the reference/presenation/architectural settings ?
This is my exemple n°3. Remove the interior walls and you will not see the room partitions anymore.
When you are on early stage of design you don't want to draw interior walls.
What is needed here is to have a space with border color different from the fill color.
regards
