How do I Isolate a floor so it shows only that floor I have selected. This is how the floors have been defined.
In Elevation this is the floor selected that I have circled in Red. The Red arrow is pointing to the floor above that I don't want to see.
This is the Isolate Active Floor settings
Hi Simon,
Can you share a screenshot explaining the position of the floor immediately above, with respect to the one set in floor manager?
I'm moving this post to the English language forum.Regards,
Duncan Brown
it is the next floor as defined in the floor manager RL 546.500. Whichever floor I select the floor above is still shown
HI Simon,
your second screen shots hides the setting for the next floor offset. the floor isolator will show all geometry that passes through the current floor and below the next floor (RL546.500) the next floor offset allows you to add positive values or subtract negative values to 546.500. these values are in working units. thus try setting the next floor offset the equivalent of 1m or 4ft whatever your working units are. this should give you a value that excludes the beams and slabs above the current floor.
rgds
Brenden
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
