Shape from dwg covers pdf
Aecosim Connect, created an empty dgn file and referenced 3 dwg files and a pdf into.
The pdf file is rotated vertical.
Problem now is that a shape in bottom dwg file covers parts of the pdf file, which should be visible. Image shows problem, I have inverted the colours from the pdf to make it more visible.
Rendering is set to wireframe, fill is off.
