We are having trouble with fills not staying behind CAD lines, even when the priority is set up correctly
eg: view in CAD space vs printing preview below
If we have drawn CAD first and then filled the fills will lay on top (and print this way)
When the fill is put down first and the CAD is drawn on top it will print fine
This is a nightmare when 99% of the time the fills will be after the CAD!
Please help!
Hi, A Service Request "7000820129: Lines disappearing in Print Preview", is already filed on one of your colleague's name.
We will further communicate through this SR. Thanks,Anik
Do you have an answer for this issue yet?
Hi Olivia,
It looks like Anik is working with James on this and one other issue, but in the interim... Are you doing something different than this?
Hi Steve, We haven't been doing it this way, we have been using the create region to fill CAD. the issues with printing isn't just with solid fills, it is also with hatches and patterns
i CAN BET YOU ARE IN A 3D FILE. This occurs in an extraction that goes straight into a 3d file or straight to a sheet.
Is the file referenced or open live a 3d file - if yes make it be in a 2d file the problem will go away
This will affect hatches, fill etc and where 3d elements get confused when they share the same space
and you have to be careful of reference order too.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
