what is the easiest way to set up and number sheets- can you link these to the text on the title blocks on the sheets so you only have to type it once?
Is there a way the sheets can auto update if you insert a sheet in the middle instead of re-numbering?
At the moment
Could Sheet Indexing be what you are looking for?
https://communities.bentley.com/products/microstation/b/microstation_blog/posts/composing-drawings-blog-series-building-design-blog-3-of-4
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/144334/regarding-sheet-index/438478#438478
