Keyboard Shortcuts have suddenly stopped working, is there a setting to turn them off and on? accudraw short keys are the only shortkeys that are working
pressing spacebar and q is not working
Please help!
It is AECOsim Building Designer CONNECT Edition Update 3 - Version 10.03.00.40
Choose File > Settings > User > Keyboard Shortcuts. Does the list display populated as you'd expect?
You can also check if the file defined by MS_KEYBOARDSHORTCUTS exists - that would typically mean user keyboard shortcuts could be overriding the defaults.
this is what pops up for me, i've only ever used the default keyboard shortcuts and haven't attempted to create other ones
Mine don't work either in the Connect version but did previously.
Liek when I select F when I am in a view and my selection should go to the FRONT NO LONGER works
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Interesting... it does look exactly like mine. As a "shotgun" approach, try renaming your prefs folder (C:\Users\your.name\AppData\Local\Bentley\AECOsimBuildingDesigner\10.0.0\prefs) and then restart AECOsim. Any change?
Answer Verified By: Larry Abla
It worked, thank you!
Great! I am glad to hear that.
Eric, you may want to try the same step.
