Hi
I read this thread and are trying to do the same, create at pile-schedule:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/162985/aecosim-pile-schedule
I try to follow the video posted as a reply, but the problem is that I can't see the building data group when I'm about to add it as an item type. Why is that?
Robert
Hi Robert,
In the model in which you are trying to generate the report, make sure you have some elements which have some DataGroup Data attached to them. Only then 'Building Data Group' will appear in the list to be included as Item Types.
Tathagata
I have elements with datagroup data in my file, but as you can see in the picture below the building data group don't show any way.
robert
Can you share the file?
0676.V003.dgn
Sure, here it is.
I opened the file using Dataset_SE and I could see BuildingDataGroup under the Item Types list.
Are you facing the issue using any of the delivered Dataset?
