OK, so the base build is humming, now to value add.
I want to take my base families\parts and keep the levels for modelling, but have the levels and colours change when creating a DV. This way I can mdel in our build and output drawings to client requirements. I'll do this using rules, as I have done with DEM, and the Family\part Drawing Symbology.
My issue is that I can't get the output to use a different level to the modelled member. If I force some settings like colours in the rules they come through, but the new level isn't being used.
Iis there a way around this as I have more than 1 bild to do this way.
Can you elaborate on how the rule is defined?
Rules are where they are usually kept I would have thought??
Works as intended in DEM.
Steve, I haven't fully tested CE, but not looking promising. Any help on this is appreciated as it means some large changes to our build and workflows if it doesn't work. I'm prepared to go back to DEM and wait for CE to work fully if that's what it takes.
Hey Sean
Are the dgnlib files from the client pre-Aecosim? I was finding odd things like this happening when using old dgnlib files. Another thing I found was the client seed files or when users were using old seed files and wondering why the views were working.
Quick question, have you worked out how to move the widgets like you could with DEM? I submitted a SR about 3 months ago and they still don't know what I'm talking about. Not Steve obviously he's awesome.
