Hi All!
I´m looking how to elaborate some specific schedules.
I need to do two things:
1- Tag walls in a very large project.
These tags should be unique by each specifica wall an slab, in order to later generate detail drawings of each of them related to the used tag in floor plans.
2- Produce hosted elements schedules.
Once walls and slabs have been tagged, produce hosted elements schedules (such as windows, doors, voids, supports).
For each hosted element , I´d like to see in which specific wall or slab the element is hosted.
Ideally, it would also be nice to produce schedules the other way: wall and slab schedules which list per wall or slab the hosted objects.
¿Is it possible?
Thanks in advance for your help.
Matias
Maybe look at whether the linkage info between host and hosted elements are exported when an ifc is generated.
