For an example if we are creating a MEP family in revit we have an option connector then we can choose pipe connector, duct connector etc..., like same how we create MEP cells in aecosim with pipe connector help me to solve this issueThanks
You may be asking how the Family and Part definitions are linked to a certain mechanical tool. In AECOsim Building Designer Mechanical it is done by using a configuration variable. There are variables availalble for each type of tool so that when the tool is selected, the correct Family will also be set. Then you can change the Part before placement depending on the type of duct, for instance.
Thanks for your reply Mr. Robert, can you guide us how to create a plumbing fixture family like this (mentioned image below)
There are dampers or flanges which look like that already in piping. You just need to place it with the correct dimension. Is that what you want to do?
That component question is also addressed in this thread: https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/168556/plumbing-fixture-with-pipe-connector
Hi Mr.Robert
Thanks for your support, i need to connect the 4 pipes by using cross joint automatically, bcz while using the"join by T or Join by cross " we get the T joined for pipes automatically but we didnt get the Cross joint for pipes automatically, we place that cross manually, any more options for apply cross joint in pipes by using automatic methodthanks
