Hi allI had an issue while connecting pipes by using cross joint, may i get the guidance to do that (attached image below for your reference)
Hi Sreedhar,
In the image I can see four different pipes, now to connect four different pipes you would need a 'fitting'. If you create two straight pipes/ducts overlapping each other you would be able to see "Connect Ducts/Pipes" option works only if your pipe or ducts overlap each other.
As a small test case you can create two ducts overlapping each other vertically & horizontally from a top view. Then right click on any of the ducts and use connect ducts option.
You can get apt tutorials in here - https://learn.bentley.com/app/Public and you can also have a look at these Wiki's - https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/7378/aecosim-building-designer
