Hi Vaishnav,
The dimensions of your elements do not change if you modify the grid. You would have to individually modify the elements for exp: walls, columns in order to do that.
So u mean the walls move away eventhough their coordinates are fixed in space ?
No, that does not happen. If you modify the grid dimensions ONLY the grid position moves. The wall or column elements stay in it's exact co-ordinates where it has been placed.
Answer Verified By: V Vaishnav
I have consolidated this information on to this wiki for your future references.
Satadal
Hi V,
Unfortunatley, the type of associative behaviour you are looking for is not currently supported when you use ABD / Triforma Forms. It has been discussed and requested many times over the years.
1. You may want using GC CE U4, which now has a Grid node. Please note that one particular problem that has been highlighted before is that any Joins between a 'dumb' ABD / TF Form like a Wall with a GC Wall do not work. Ditto for any associative Mstn elments like associative dimensions.
So, when a GC Wall is flexed, any walls connected to it using a TF Join will not maintain its connection, requiring manual clean up.
At least that was the result the last time I look at this. It would be good to see it things have improved.
2. You may also want to try using Mstn's CE's Parametric Solids, which can make use of 2/3d Constraints. Unfortunately, I don't think that ABD/Mstn allow the Constraints tools to work on the Grid elements.
Eventually, I hope that ABD's TF elements would be converted to be variants of Mstn's Parametric Solids, and a smarter dependency manager that can deal with all elements (more like R*vit) will be put in place.
