AECOsim IFC/COBie export error
IFC Mapping are shown in red. I guess this is because the value of the path that locates the ifc_2x3_entities.xml file is incorrect or undefined. However; I can not locate the configuration variable that should have the correct path. Any ideas?
Parents Reply
  • It's irrelevant whether your dataset is managed by ProjectWise or local, the key factor is whether you have the same DataGroup components as the person who created the DGN file.   If those components are missing in your dataset, they will not be mapped to corresponding IFC entities.   The easiest test would be for you to place a few components similar to those already in the file, and then export again to IFC again.  If your components are exported correctly then you'll need to work with this other person to figure out what it is you need.
