When you use the Insert Vertex on a slab, it works as desired. When you zoom before confirming the position of the new vertex, it doesn't. It used to work in V8i, but seems to be a bug in Connect.
Hi Stefan,
Thank you for reporting this, I have filed Defect 954517:'Insert Vertex on Slab Form fails if zoom operation is applied after datapoint is confirmed'.
Marc
Answer Verified By: StefanC
hi Marc
I noticed it's not only when zooming but in other manipulations of the view too (orbit).
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
