I am using the Bentley AECOsim suite to model a new CMU building and I am having issues rendering the block in the correct size/placement location. The block is 8"x8"x16" and is modular per the building dimensions.
I attempted to use the following link for help but I don't have the ability to adjust the dimensions in the X or Y direction. https://communities.bentley.com/products/microstation/w/microstation__wiki/16810/adjust-material-pattern-map-to-have-correct-scale
Currently, I have the blocks sized close to what I need but top and bottom blocks in the rendering are 1/2 blocks instead of one block which causes issues with the layout of all the block. See the attached PDF for more information.
Any help I can get in verifying the size of my CMU block and adjusting the layout will be greatly appreciated!
PDF
Hello Andrew,Please see this video and let me know if this helps.RegardsAditya
