Has anyone managed to get OPM models come through in DEM when referenced into an AECOsim model for mutli-discipline drawings?
Hi Sean,
The implication of your question is that you have tried that and they do not? What was the result?
I'm not familiar with OPM but this could be a case where CV will provide the results you need?
Marc
That depends Bear, I have not used DEM for a long time but have found issue with building views
what format do you have to contend with?
I have found issues with OP's Aecosim models, more so than with ifc or dwg etc.
With the Aecosim models I have found that sometimes I have to copy/merge the data into new files in order for it to display
The result to far MArc has been nothing. Not a single piece of graphics coming through. Not happy.
My worst fears are coming true. Gone are the days where I could use the dgn files of different packages and still produce drawings.
Ironic that hln files are the most successful method.
I gave up with CE and then DV's to stay with SS6 and DEM. Only issue I have now is that I'm stuck with OPM dgn files not coming through in DEM.
The reality for me is that until CE fixes the bugs and DV has much better functionality I won't be moving. Just working on more work arounds.
what discipline are the OPM's Bear?
