Never had this before, but I have seen it in another SS6 build. If I run a few extractions in a file, all the views backout and the only way to restore is to restart the file. Has anyone else seem this and found a fix?
Hi Bear,
Can you please share some screenshots showing the workflow and setting you are following?
Warm Regards,
Subhamoy Kundu
Our drawings have everything we need for the drawing internal:
Master Reference - base reference file model and also where we create the extractions
Design Model - extractions are referenced into there for most drawings (very rarely directly referenced straight into sheet), where we also add extra linework like CL.
Group Models
Extractions
Extractions are pretty std. Nothing too fancy:
Run 'Calculate All' and all graphics disappear. Only way to get the back is to restart the file.
Are the extracted graphics missing in the extraction model itself or only as reference attachments to the Design Model?
It's every model Steve. Almost like there is a memory issue and elements just won't display. Only happens once you've run a few extractions.
Hmmm.... so if you directly open the extraction model itself there are no graphics displayed? But if you reopen the DGN file and then navigate to that same model, now the graphics do display?
If I go to ANY model the graphics aren't displayed. Restart the file and all is good :-(
Huh... I'm not sure what to make of that. And honestly it rings no bells whatsoever. Any chance your graphics card has updated drivers available?
I thought that at first as well Steve, but it's multiple firms all using different machines. My home machine included.
OK, thanks. Since you're seeing missing graphics in every model, not just the extraction, it does sound like it's something at a file level, particularly if the results are the same on multiple machines with different configurations. It's is a mystery...
