I'd like to know if it is possible to set MS_PLOT_VISEDGE_OVERRIDES at print time. We generate a variety of drawings at varying scales which each would require a different level of detail.
It seems to me like this should be set in a plot config file and not a config file.
Hi Simon,
Can you confirm which CVE parameters you want to see during the printing?
Thanks,Aniruddh
Hi Ani
I'd expect to see whatever parameters that can be defined by the variable I mentioned.
Hello Simon,
I checked with my internal team and found that it is not possible to set this Variable during printing.
also an Enhancement is already logged against this user requirement.
Regards,Aniruddh
