Inserting parts in Plumbing?
New to AECOsim and I am in discussion for training but in the meantime I am feeling my way thru.
I feel like there should be an easier way. I have two pipe lines that are suppose to intersect, but when I go to place the four way connection, the symbol only lets me insert by one connection, so then I move along the line to the correct spot, then I need to rotate for the line that I placed it on, than rotate for the second line, then break both lines and connect all 4 pipes.  I am sure their should be an easier way than all the CAD efforts I am doing.
  • Hi Jose,
    Just to be sure - which version of AECOsim are you using?
  • currently we are using AECOsim Building Designer V8i (Select Series 6) Version 08.11.09.866
    Beside the interface is there a major difference with the AECOsim software between V8i and Connects version?  Our client is in V8i so we started with AECOsim V8i...
  • There is a difference behind the scenes too, which makes them not always fully compatible.
    Also, Connect is 64-bit vs 32-bit for V8i.
    Windows 10 pro
    OpenBuildings Designer Connect Edition Update 10.10.01.151
  • Very good points thank you for that information.  My first question was how do I insert a part and then I was asked what version.  I have seen both and insert a part is done basically the same way in both version; that is why the version question threw me off.
    I am still waiting to see if there is an easier way to insert a part, than all the CAD I was doing previously (see my first question).  My client is in a hold pattern now so, I am just trying to figure out some issues I ran into while I was working on the model file.
    Thanks StecanC
  • Hi Jose,
    It's important to include the version being used for two primary reasons:
    - Tools and tool behavior may have changed between versions
    - Using the same version allows others to replicate the issue/question using that same set of tools and behavior.
    In regards to your question, see if the steps outlined in the attached video help.
Reply
  • Hi Jose,
