New to AECOsim and I am in discussion for training but in the meantime I am feeling my way thru.
I feel like there should be an easier way. I have two pipe lines that are suppose to intersect, but when I go to place the four way connection, the symbol only lets me insert by one connection, so then I move along the line to the correct spot, then I need to rotate for the line that I placed it on, than rotate for the second line, then break both lines and connect all 4 pipes. I am sure their should be an easier way than all the CAD efforts I am doing.
sorry to say but this inserted a 3 way and then flipped the 3 way for the 4th connection, this did not place a 4 way. I tried a few times with the same bad results. I hope the training will help resolve these issues and other questions I have.
Training is certainly a good idea and will hopefully help you to utilize the tools and workflows to best achieve the desired end results.
