Is there a check tool that identifies elements with no assigned parts & families?
Hi Yehia,
Please use 'Verify Part and Family' tool to check the same. Please let me know if that helps.
Warm Regards,
Subhamoy Kundu
The verify part & family tool just mentions the valid & invalid parts already assigned to elements. I am asking if there is another tool/way to check the unassigned elements.
I Yehia,
Verify part also shows elements which are unassigned. And it creates a report i.e.text files for valid, invalid and missing part/family elements.I hope you are looking for the same.
Please see Image below
Answer Verified By: Yehia Elsayed
Thank you Smita!
Do you know how i can do the same regarding the elements without datagroup information?
Items will list those objects with DG information by their Catalog Name. If there is no DG information the list will say "Triforma". You can isolate the elements under here to visually see what is missing DG information, then assign the data as you need. In CONNECT Items can be found in Explorer.
