I get the following error when i try to open the symbol manager = "The tool is not supported in a managed workspace environment." The file is obviously electrical, registered and all other buttons under electrical tabs work normally.
Any idea?
Hello Yehia,
Could you please confirm the AECOsim version and ProjectWise version number?Furthermore, Electrical portion of AECOsim has some Restrictions and Limitation with ProjectWise Managed Configuration.One of them is Symbol Library/Manager is available in Read-Only Mode.
If you are using AECOsim V8i version then, please refer below deployment guide. (Page no. 1 onwards)AECOsim Building Designer V8i (SELECTseries 6) Deployment Guide: ProjectWise V8i Managed Workspaces – v4.3
If you are using AECOsim CONNECT version then, please refer below deployment guide. (Page no.45 onwards)AECOsim Building Designer CONNECT Edition Deployment Guide: ProjectWise Managed Configuration v1.2
Regards,Aniruddh
