Select all specific catalog instance in model
Hello good ABD Community,
I have a question that it sounds simple but I haven't figured it out yet.
Is it posible to select all elements instance in one model?
For example, lets say you have an specific structural catalog item, like a beam, that is repeated 10 times, and I want to select those 10 beams to change some properties. Is there a way to do it?
  • Hi Rafael,
    Yes you can do this easily in AECOsim Building Designer with the help of Displayset Set. You can check the video I have attached for your reference. I hope this helps.
    Sanchayan
  • Hello Sanchayan,
    Thank you for your reply!!
    I don't want to be "that guy", but....is there an easier way to do it?
    You can see in this video that in Revit is very simple
    https://www.youtube.com/watch?v=NIyh8h_3DtM
    But in ABD I jave to open en excel chart? Don't you Bentley fellas think that's a bit....overcomplicated?
  • Hi Rafael,
    Are you looking for something like this?
    Answer Verified By: Rafael Bombardiere Carvajal
  • Thank you Steve!!!
    Something like this I was looking!!
    I wish it was a little simpler though.
    Best Regards
    Rafael
