Using the Dataset Explorer, there's a pick-list that allows you to select which aspect of the part to edit. In your case, you'd want the Drawing Symbology settings to match the Definition settings. Though I have to admit, that's pretty unusual... Most seem to want something entirely different in their extractions vs. the 3D model, hence the differences in our delivered datasets.
HTH
ok. Thanks
